84 300sd ac/heater blower motor acting weird. Help would be appreciated...
For some reason my blower motor quit working, except when my engine is revved up to high rpms. After observing it, I think that the blower RPM is directly related to engine RPM, which is just totally weird as far as I'm concerned. Honestly, it gains RPMs as my engine does.... Then it just blows heat, no matter what I do to the settings. Blower was replaced last summer, and the AC compressor is fine (although I wasn't able to be sure if it was coming on or not when i was playing with the settings). I also checked the fuses for the fan, which are fine. I've got a 300 mile trip coming up as soon as it starts to get hot around here, and would like to get this resolved so I don't have heat blasting at my face while my cars going 3800 RPM for 5 hours. Assuming I can't get this fixed before my trip, should I just go ahead and pull the fuses for any/all heater/ac related systems?
Thanks for any suggestions in advance!
__________________
__________________
There is a fuse for the blower motor under the hood, by the master cylinder area it is covered by a plastic cover and it is flat fuse held by two screws and it does not look like a regular fuse. If it is OK press the defrost button and see if blower comes on if it does it might be your pushbutton control unit. Hope it helps.
