S-Class (W126) 1979-1991: 300 SE, 300 SEL, 380 SE, 380 SEL, 420 SEL, 500 SEL, 560 SEL, 360 SEC, 500 SEC, 580 SEC, 300 SD TURBODIESEL, 300 SDL TURBO, 350 SD TURBO, 350 SDL TURBO
What are the benefits of larger wheels/tires...
Old Aug 16, 2005 | 11:38 PM
kevinrea's Avatar
2002 S500
Hi guys,
I was wondering. my 1990 560SEC has 15" wheels/tires on it.
is there any benefits other than paying more for tires that one could receive from 16" or 17" wheels and tires ?
thanks,
Kevin
Old Aug 16, 2005 | 11:52 PM
CE750's Avatar
'05 E320 CDI, '08 BMW X5 4.8i, '11 Duramax 2500HD
Originally Posted by kevinrea
Hi guys,
thanks,
Kevin
generally better handling, but there is a diminishing return after 17" wheels... the rest are more for looks.
Old Sep 4, 2005 | 01:23 PM
Den.'s Avatar
Currently on foot.
Agreed. When you start getting into 19-22" performance is actually degraded plus it looks retarded. (There's a W140 I've seen around the bottom of Etobicoke here with 20's or 22's and I laugh out loud everytime I see it!!)LOL.
A larger rim and smaller sidewall has less flex due to the smaller sidewall. But it will normally also make the car ride rougher. If you go plus 1 or 2 it would usually be a good compromise.
A wider tread will give you better roadholding. Though you supposedly could see less fuel mileage.
Just keep the wheel diameter the same as then you don't have to worry about speedo error!
