S-Class (W126) 1979-1991: 300 SE, 300 SEL, 380 SE, 380 SEL, 420 SEL, 500 SEL, 560 SEL, 360 SEC, 500 SEC, 580 SEC, 300 SD TURBODIESEL, 300 SDL TURBO, 350 SD TURBO, 350 SDL TURBO
Thermo time switch
Old Oct 23, 2005 | 02:52 AM
bcmbcmbcm's Avatar
380 SEL 1982
Thermo time switch
Can anyone explain what the thermo time switch does and where is it located on a 380 SEL?
Thanks!
Old Oct 29, 2005 | 10:56 PM
w123_w126's Avatar
85 500 SEL
It controls the cold start valve, shutting it off at 42 degrees F.
It’s located on the upper part of the intake manifold.
Old Oct 30, 2005 | 11:23 AM
bcmbcmbcm's Avatar
380 SEL 1982
Thanks! What does the cold start valve do?
What does the cold start valve do? What are some symptoms if either is failing?
Old Oct 30, 2005 | 02:04 PM
w123_w126's Avatar
85 500 SEL
The CSV introduces additional fuel to a cold engine to aid starting and warm the engine faster. Hard starts in cold weather with a cold engine and flooding in a warm engine are two common symptoms of failure.
Old May 3, 2006 | 04:13 PM
bcmbcmbcm's Avatar
380 SEL 1982
what if the engine runs WORSE when warm?
I have figured out that my engine runs like a champ when ice cold, but when
I reach 40 degrees I get a little off idle hesitation. I have changed my thermotime
switch. Does this mean that the CSV is at fault? Is it simply 'on' (more fuel=more power) or
'off' or are there variable levels of operation?
Also, can I bypass the CSV so I get max fuel all the time?
