83 300SD ignition/steering problem. Any suggestions?
![Arrow](https://mbworld.org/forums/images/icons/icon2.gif)
I can put the key into the ignition and turn it about 1/8th of an inch clockwise, but before it will get into the no.1 position. It will not go any further, and the steering wheel is locked. I cannot break it. Im thinking it may either be a stuck tumbler due to the cold, or a bad steering column. I was not given a notice that anything may go bad; there were no warnings. Has anyone out there experienced a similar problem; or better, a resolution?
thanks.
-Paul
1980 300D w123 non-turbo 4speed manual 225k miles
1983 300SD w126 545k miles
thanks.
-Paul
You cant move your steering wheel even a little bit?
I experienced a similar problem, but all i had to do was move my steering wheel. I heard a click and i could then turn the key all the way over. I was told that it happens to some cars after the steering wheel has been turned when the vehicle is parked.
Hope this helps-
Hope this helps-
Ignition Issue!
I can move the steering wheel a little (maybe 25degrees), and I feel somewhat of a click. I can play with theh wheel and key ignition for a while however I can not put the key into the number one position. Also, a friend of mine advised me to put the car into Neutral and move it a couple inches while trying to start it. I did; still nothing. I think I am going to go play with it some more today when the weather gets nicer and I will let you know. Im also thinking the worst case scenario: Replace the column and ignition.
Thanks.
-Paul
Thanks.
-Paul
