300SE steering wont go back, HELP!!!!!
Hi guys, today I puled the little switch by the side of the steering wheel to bring the steering forward so that i can take out the dashboard and clean the inside (lights were dim)
The thing is that after cleaning and putting it back (the dashboard)when I try to push the steering back down it wont move. Its as though there is no response, no sound at all.
How do I move the steering back down I only unplugged the wires from the back of the dash and nothing else, could it be that the motor has suddenly blown just like that, or a plug came loose but how and where is it? I checked below (opened up the portion below the drivers area) and all the wires were intact.
Is there a manual way to adjust the steering back down, as its really hard to drive with the steering back all the way.
thanx in advance...
thanx in advance...
ok finally Im back, from a long needed vacation...
I just checked my steering and I found out its the motor that has some problems...
when I pull it up (to make steering go up) it makes a sound but cant come up anymore as its already at its max. but when I push it down (to make steering go down) it does not even make a sound...
does it mean that the motor is spoilt or just that its stuck?
is there a manual wrench or something to push it down manually?
anone selling a steering motor?
