S-Class (W126) 1979-1991: 300 SE, 300 SEL, 380 SE, 380 SEL, 420 SEL, 500 SEL, 560 SEL, 360 SEC, 500 SEC, 580 SEC, 300 SD TURBODIESEL, 300 SDL TURBO, 350 SD TURBO, 350 SDL TURBO
Airhose
Old May 16, 2006 | 04:09 PM
houston300sel's Avatar
'90 300SEL '02 ACCORD '84 944
Question Airhose
Does anyone know how to find the airhose on the engine ? I have a 'studdering' problem, at idle, like a cylinder is not firing. It sputters as you take off, then smooths out as revs increase. Car has new dist cap, rotor, new ignition wires, new plugs, and new fuel filter.
Old May 16, 2006 | 04:11 PM
Reynaldo's Avatar
'03-ML350 'inspiration'
In store.
Old May 16, 2006 | 07:03 PM
egxpimp's Avatar
F248 F1
Air hose ? What do you need that for ? I have the same probelm....hmm what did you find out ?
Old May 16, 2006 | 07:07 PM
StapleGun's Avatar
1967 Morris Cooper "S", 1983 911SC, 1997 Toyota Tacoma, 1999 HD FXSTB, 1998 C43
Dunno about 'air hose' - sounds like you have a vacuum leak somewhere.
Old May 16, 2006 | 07:10 PM
egxpimp's Avatar
F248 F1
Hmm interesting, maybe i can solve my problem after all. Do you know which vaccum hose can be the potential culprid ?
Houston, which vaccum hose was leaking for you ?
Anyone have ideas how can i can check which one is leaking ?
Old May 22, 2006 | 10:49 PM
Thanks for your interest guys. I've got the car running very smoothly, but, after it heats up it will 'stutter' at idle. I don't know how to test for vacuum leaks but I've been reading up on the different techniques and I will give it a go. Wish me luck. I originally read to check the airhose on another site that's why I asked ??
