Opinions on 126 Diesels NEEDED!
1981-85 300SD Turbodiesel
1986-87 300SDL Turbodiesel
1990-91 350SDL Turbodiesel
What I am looking for will be a very clean, meticulously kept and maintained Auto that can be treated the same but turned into a weekly driver. The occaisional 400-800 mile Texas Road trip will be required of it. I intend to use it regularly.
I'm dying to hear any and all opinions.
Thanks and gald to be a new member. This place will served as home away from home as I move into this car and stay with it for a long time.
Texas126
I like the options the 350 series came with, but will not buy one that has the original motor in it! For what ever reason
, the 350 series motors that I have seen that have 120-150 thousand miles on them have one bad cylinder or one bent connecting rod.If you can find one that has a MB reconditioned motor in it, you should be ok.
One Last question, any clue the cost to have an MB Refurbished/Remanufactured 350 SLD engine installed?
Solid long body with a stout turbo 6 cylinder.
Most have had the original head replaced.
Con?
No intercooler.
87' original heads crack!
Mine, I don't remember the mileage due to the fact it has been in the paint and body shop for the last four months and before that, I had loaned it to my mother for three months. I think it has less than 150K (and has the original head).
The exterior was a 4 out of ten, interior is 6 out of 10, mechanicals were 5 out of 10.
__________________________________________
Things I have done:
Front suspension, all steering leakages, upper and lower ball joints, radius rod bushings (?).
Chassis bushings front and rear.
Trans and diff mounts.
Radiator
Fuel level sender
Things that need to be done:
Paint job (in the works)
Replace windshield (in the works)
Interior cleaned and re-died
Install 91’ model door panels (bought)
Install 91’ model rear deck speaker housings (bought)
Install new stereo speakers and amps (have)
Euro headlights installed (bought)
HAVAC control rebuilt
Heater control valve (mono-valve) replaced
Replace oil cooler
I would not buy a 3.5L 603. Simply a poorly designed engine. The cylinder walls are extremly thin. Only if a super nice 350SD came along would I consider one. I have a weak spot for the SWB W126's.
Kris
Maybe OJwerks could be referring to the engine? A V8 always looks better than a 6, no matter what engine bay it's in!
https://mbworld.org/forums/diesel-forum/186747-thinking-getting-diesel-126-a.html
