S-Class (W126) 1979-1991: 300 SE, 300 SEL, 380 SE, 380 SEL, 420 SEL, 500 SEL, 560 SEL, 360 SEC, 500 SEC, 580 SEC, 300 SD TURBODIESEL, 300 SDL TURBO, 350 SD TURBO, 350 SDL TURBO
Stranded in Edmonton with Electrical problem
Old Jul 30, 2006 | 04:27 PM
mbdvr's Avatar
A call for help to the electrical gurus of the board.
I am now about 2500 miles from home with a 82 380 SEC that has decided to give me a little trouble shooting exercise.
The power windows suddenly stopped working. No noise at all from any switches. Fuses all OK.
At least they were up when the failure occured.
When it started raining, I turned on the wipers and they had also stopped working. No action from any of the positions.
I noticed later that the driver's power seat also stopped working.
Related probelm???? All fuses appear OK. As it was raining, I did not remove and clean, but see that for ALL these accessories to quit, many fuses are involved.
What about a main cable to the console? Circuit breaker? Relay?
Sun roof works. Radio works. Engine seems fine. Other interior items OK.
I am without my disk set of skematics, holed up in a Starbucks and hope to get some input from the forum so I can venture back the the USA!
Old Jul 31, 2006 | 06:19 AM
mbdvr's Avatar
It was a fuse
After finding a dry place to thoroughly check the fuses, I found #7 to be the culprit.
The end was bad. From the fiirst quick look all appeared OK, but I had to pull the fuse to see the end was no longer making good contact.
Thsi fuse feeds the 86 pin on the window relay.
