S-Class (W126) 1979-1991: 300 SE, 300 SEL, 380 SE, 380 SEL, 420 SEL, 500 SEL, 560 SEL, 360 SEC, 500 SEC, 580 SEC, 300 SD TURBODIESEL, 300 SDL TURBO, 350 SD TURBO, 350 SDL TURBO
Radiator replacement
Old Aug 3, 2006 | 04:26 PM
pfginc's Avatar
About 1 inch of the neck on the radiator broke off I was able to get the hose connected to the shortened neck but want to replace the radiator. I have seen replacement parts from $160 all the way up to $400 for the behr brand. My question is if the behr is known for neck breakage wouldnt it make sense to try another brand while saving a couple hundred bucks? Any brands that anyone would recommend???
Old Aug 5, 2006 | 03:52 PM
egxpimp's Avatar
F248 F1
actualy behr now reinforced the neck, they have a steel plate around it. So go for the behr, it is pricey but well worth it, i had to replace mine after 26 years. They last alonggg time-well worth it.
