S-Class (W126) 1979-1991: 300 SE, 300 SEL, 380 SE, 380 SEL, 420 SEL, 500 SEL, 560 SEL, 360 SEC, 500 SEC, 580 SEC, 300 SD TURBODIESEL, 300 SDL TURBO, 350 SD TURBO, 350 SDL TURBO
1991 560 SEL fan blower fuses
Old Sep 8, 2006 | 12:22 AM
AgieDC's Avatar
I am researching my options for the fan blower on the 1991 560 SEL which recently quit blowing. I believe the freon is fine as the compressor works well and tests full of freon. However, I am unable to verify the fuses for the fan blower. I have read posts discussing the in-line fuse, however I am unable to download any pics and just can not seem to locate this fuse on the firewall. Secondly, if I am to inspect the blower, is it under the right passenger dash? Is there an easier way to jump a connector to test blower function? Thank you for any comments, and I did check the "ignition key backed off slightly" which seemed to have no benefit to starting the blower. Thank you. Chris
Old Sep 13, 2009 | 06:43 PM
SamH's Avatar
560 sel
Fan blower
I have the same fan blower problem. How did u resolve yours?
Sam
