S-Class (W126) 1979-1991: 300 SE, 300 SEL, 380 SE, 380 SEL, 420 SEL, 500 SEL, 560 SEL, 360 SEC, 500 SEC, 580 SEC, 300 SD TURBODIESEL, 300 SDL TURBO, 350 SD TURBO, 350 SDL TURBO
Engine shuts off !!!!!!
Old Nov 23, 2006 | 08:17 PM
Boss-Benz's Avatar
hey I am new here, and I just bought my first Benz 1987 SEL 420 and every time when I turn right car shuts off, and it is only when I turn right. If anyone can help me that would be great.
Thanks,
Old Nov 24, 2006 | 01:42 PM
jhodg5kc's Avatar
ON SUSPENSION
Quite a few:)
try cycling the key a few times, see if that helps.
If that doesn't help, try giving it some 'gas' (air) when you start..injectors may be leaking down.
When was the last time your ignition system was gone through/inspected?
You should run a few doses of Techron through your system (change the oil/filter afterwards).
Jonathan
Old Nov 26, 2006 | 09:38 AM
mramay's Avatar
1987 560SEL, 1987 570SEC
I saw one car that did that and it was the wire from the distributor to the coil that was broken under the insulation at the coil. Turn right and the motor moved just enough to break connection and the engine would die.
Start your engine and then start gently tugging on the wiring around it to see if any of it makes the engine quit. Also, take a look at your motor mounts to see if they're letting the engine move more than it should.
