Carbon Monoxide Leakage into Cabin?
Today for some odd reason, I was exiting the freeway and the engine began to smoke very similar color white smoke which began to enter the cabin as well. After pulling over and popping the hood. I realized the smoke seems to be coming from under the engine near the cars insolation. (see picture - Note: Found pic online) I let the car rest for about half an hour while I ate lunch.
After lunch, I popped the hood and there appeared to be vaporized heat coming from the same area of the engine. On the way home there was an odd smell coming into the cabin, it didn't smell like burning oil or gasoline and gave me a headache after exiting the car. What could be going on here?
Thanks for your help in advance.
The area behind the aluminum pan has a black plastic tube which recirculates exhaust gas to be burnt off in the engine (another is located passenger side front of pan) and if this is disconnected the gas would be all over the engine bay. Make sure it is plugged into the aluminum tube located under the pan, just in front of the red area in your photo.
Did you remove the pan to see if there is any other leaks under the pan?
