HELP! 1990 w126 560SEL alarm malfunction
Wow, heres a new on on me. HELP!!!!!!!!!
When the car is running, and I step on the brakes, the auto alarm goes off. I have to pull over, shut down, restart (without stepping on the brake) and then drive away. I do this by leaving it in neutral.
Also, when I open the right rear door, the alarm beeps once.
Hmmm, what gremlin is responsible for this?
1 Post
1991 Mercedes-Benz 560 SEL
Your locks should all lock together using any of the 3 locks (Driver/Passenger/trunk). When locking the vehicle from the trunk and removing the key when turned to the 3 o’clock position you will activate the alarm.
The alarm system monitors the doors and light circuits. If a door is opened the draw will trip the relay and activate the alarm system. Funny that you say it just goes off when you hit the brakes. Does this happen ALL the time? How long have you owned this vehicle?
You have some sort of short that is back feeding. Narrowing it down should not be too bad. Try some of the above and let me know what you find. Also have a look to see,
(1) The dome lights are working when doors are open (Check the ones on the bottom of the door to ensure they have not fallen out or become grounded)
(2) Check to ensure you have no burnt out tail lights or turn signals.
(3) De-activate the alarm as I mentioned above. Does this stop it from happening?
fixed it, sort of
Did you try and dis-arm the alarm by putting the key in the trunk and turning counter clockwise? Be sure to pull the key out at the 9 o’clock position.
yup, tried that. no luck![Smilie](https://mbworld.org/forums/images/smilies/smile.gif)
yup, got that, tried, arms and dis-arms just fine.
owned it more than a year, brakes are fine, pads in good shape, sensors tested good.
it started one night, lights on/off no difference, it just went off, then I noticed it only happened when i hit the brakes.
I'd shut the car off, alarm would stop. start the car, no alarm, step on brakes, ... alarm. Hmmm. shut car off, put car in neutral, start car, no alarm, put in drive, no alarm, step on brakes... alarm. Hmmm.
after getting home, it would also "beep" once, only when the right rear door is opened. I figured a short somewhere.
yup, all good.
yup, all good
nope.
so, I disconnected the alarm. Oh well.
but hey, thanks for the reply.
This car has over 250k, and has been a wonderful car.
yup, all good.
yup, all good
nope.
