S-Class (W126) 1979-1991: 300 SE, 300 SEL, 380 SE, 380 SEL, 420 SEL, 500 SEL, 560 SEL, 360 SEC, 500 SEC, 580 SEC, 300 SD TURBODIESEL, 300 SDL TURBO, 350 SD TURBO, 350 SDL TURBO
W126 Climate Control Lightbulb replacement
Old 03-05-2007, 11:24 PM
davidrap's Avatar
Mercedes 560SEL
Hi!
I have a 1987 560SEL. The lights on the climate control recently stopped working. I know these are bulbs and not part of the fiberoptics in the dash.
Does anyone know how to change these bulbs?
Do you have to remove the climate control unit and open it up?
Thanks,
David
Old 03-06-2007, 05:01 AM
420 SE's Avatar
W126 420 SE 1988
Is it the temp wheel or the buttons?
If it's the temp wheel, then via the trans kick panel, if it's the buttons then via the console panel.
Old 03-06-2007, 02:15 PM
davidrap's Avatar
Mercedes 560SEL
560SEL Temp Bulbs
Actually its both buttons and temp wheel.
So the unit needs to be removed and opened?
Can I get the bulbs at auto parts store or is that a dealer item?
Thanks,
David
Quick Reply: W126 Climate Control Lightbulb replacement
