S-Class (W126) 1979-1991: 300 SE, 300 SEL, 380 SE, 380 SEL, 420 SEL, 500 SEL, 560 SEL, 360 SEC, 500 SEC, 580 SEC, 300 SD TURBODIESEL, 300 SDL TURBO, 350 SD TURBO, 350 SDL TURBO
1986 300SDL Clock Resistor
Old May 16, 2007 | 12:27 AM
JWPinkham@gmail's Avatar
I just replaced both capacitors on the clock circuit board on our 86 300SDL.
However, a resistor on the board has overheated, causing the board to blacken. I could pull the resistor off the board without using a soldering iron. It's impossible to read the resistor color code.
Anyone know the correct resistor value?
Thanks!
