380 SEC in Dubai (Some Issues)
Hydraulic Central Lock
Is not working anymore. I have to open / close every door manually. Happened suddenly. Were is the problem, what I have to replace, to look for?
Economy Instrument Indicator (Picture Two)
Not working anymore. Stopped Suddenly with the Odometer. What I need to replace or to look for?
Odometer (Mileage) Indicator
Is not running anymore. What happened? What I need to change?
Engine Temperature
Car is really getting hot here in Dubai. Especially when AC is on. With full power. Raises up to 100° C. No wonder. 45°C temperature and relative high humidity. What can I do to keep engine temperature down? I have put coolant instead of water. Additional fan is working. But sometimes very loud. Cannot be heard inside the car only from outside. Its louder than the engine.
Everything else is in excellent condition. So here the data which is needed to be able to provide a detailed answer.
Mercedes Benz 380 SEC 1983
8 Cylinders 204 Horse Power
THANKS IN ADVANCE
Engine Temperature
THANKS IN ADVANCE
Your economy gauge runs off vacuum also (a different vacuum system however) you will need to trace vacuum lines to see if something has become disconnected.
Odometer, the little gears that drive it can break, I'm sure there has been a write up about it - you need to do a search.
Engine temp can be one of many things from radiator core to thermostat etc, again, do a search on it, there have been a number of posts narrowing down the various problems.
Nice car BTW.
I overnighted in Dubai earlier last year to break the journey from Australia to the UK (flew on Emirates), busy city, lots of shopping (my wife liked the shopping).
Check your fuses, replace any aluminum fuses with copper ones and clean the contacts i the fuse box. Check the electrics at the pump to see if there is current getting to the pump.
If there is a vacuum leak and the pump has cycled unsuccessfully it may shut down. Disconnecting and reconnecting the battery will reset the pump.
THANKS IN ADVANCE
i live in the uae too... ever since summer started the engines goin really hot especially in stop and go traffic, it reaches 90-95 in stop and go traffic (which is most of dubai and sharjah) and goes slightly below 90 at highway speeds this is only during the afternoon. due to the continous contruction in the city, a fine layer of dust gets stuck in the radiator grill... this doesnt let it do its job right and may affect its efficiency to a point... especially in this weather... hit the radiator with pressurized water and clean it thoroughly... my mechanic put 20 % water, and 80 % coolant... thts his advice as for best mix for the weather here.... did you just put coolant?
the additional fan is always on, even before the engine is started, when i put the key in the start position, i can hear it start... have ur mechanic do this set up. i think it may help. or set it to start above 80 C , which is basically the same thing these days.:P
and nice car btw... how much do you think ur wheels are worth if bought from here? im looking to replce my stock steel ones with something like them.
You are absolute right with the temperatures. I just put coolant. Is that not good?
And I will get the radiator grill cleaned. Very nice thought! But is it "healthy" for the car that water comes in the engine?
I really don't know.Dubai ist ONLY stop and go traffic, its really crazy. I cannot drive 1 kilometer without using the brakes. IMPOSSIBLE. Crazy drivers, crazy traffic, crazy heat, crazy buildings
everything is crazy here. Regarding the rims: These are original AMG rims, they were on the car, when I bought it. I really don't know the price. But my spare wheel is ORIGINAL 1983 WHEEL.
Never ever used. Looks so new. Must be expensive huh?
when i said hit the radiator with high pressure water, i meant the radiator ONLY... NOT ENGINE!
PLEASE DONT DO THT! just the slim thing between the additional fan and the main fan... just so we are clear! it has all those thin grooves where dust settles in and doesnt allow air to pass thru hence preventing cooling of the fluid passing thru the radiator. the rest is history.and nice knowing someone from the area too!
it just stays right.
