A/C problems - Worse Case Senario - COST?
1 Post
2001 E320
If the a/c isn't working on a 1990 560 SEC, in a worse case senario, what would it be and what would repairs cost? Not looking for a small electrical problem or low on Freon, but rather when something expensive has gone bad...
Thank you!
Thank you!
2006 E320 CDi, 2008 3/4 Ton Suburban, 2007 "rice rickshaw" Accord 5 speed
RU a three bugger? I mean tree hugger?
If you are Naderite you are screwed. Big dollars are needed for a new R134a system and the relative inefficiency. There is nothing to replace the good old Freon system.
If you are sane and sensible you are in luck. Know the guy who services your home AC? Give him cash and get him to pump your system with the good old stuff. Better still. There are guys who can refill your system for less.
There is nothing better than the ozone gases or whatever Al Sore calls global cooling or warming (farts?) gases. If he stops preaching there would be less hot air to add to his imaginary global warning.
2012 W212 E350 Bluetec
If that is the question, check out the "Buyer's Guide" at either the MercedesShop or MBcoupes websites. If I recall correctly, they said to deduct $2,000 off the asking price for a non-working A/C on an SEC.
If you look at list prices for different parts of the A/C system, you will realize it could be more
![EEK!](https://mbworld.org/forums/images/smilies/eek.gif)
Cost me $3500
New compressor
New Cabin controls
New Relays
New Dryer
New Freon... did not convert to R134 because it does not cool as well and the price per pound was about the same.
Lots of Labor
One year later had to replace High Pressure Fan switch for about $175.
Now I am looking at the cooler element in the cabin for $2700 (quote).
New compressor
New Cabin controls
New Relays
New Dryer
Lots of Labor
Location: Grass Valley, Northern California / Gardnerville, Nevada
1991 560SEC AMG & 1995 E420 & 2013 BMW 535i DINAN & 1967 Cougar
I am looking at the same exact problem with a totally non-op AC and heat going on in a 1991 SEC.
(Gulp).
It was last serviced about 6 years ago or so, still with R12. It worked to a week ago, I will check the fuse first, then if that doesn't do it, BOHICA
(Gulp).
