S-Class (W126) 1979-1991: 300 SE, 300 SEL, 380 SE, 380 SEL, 420 SEL, 500 SEL, 560 SEL, 360 SEC, 500 SEC, 580 SEC, 300 SD TURBODIESEL, 300 SDL TURBO, 350 SD TURBO, 350 SDL TURBO
300 SEL Motor Missing
Old Sep 1, 2007 | 03:55 PM
taktiks's Avatar
1988 Mercedes-Benz 300 SEL
I had the head machined 3000 miles ago and now I have a miss. Pulled plugs and all were oily. Shop that worked on head is now out of business. THe oily plugs seems like valve guides, right? If so, I will have to pull the head myself and bring it to a machine shop. What should I have them check and do?
I replaced the plugs and air filter and put in an injector cleaner. Ran great for about an hour. Plugs are oily again.
Thank you
Old Sep 12, 2007 | 09:37 PM
gkhagler's Avatar
1990 300SE
Fouled Plugs
I would advise you to have a cylinder compression and leak down test. This would give you data to take a better decision on a repair. You don't want to pull the head again and find that you have a bottom end problem.
