S-Class (W126) 1979-1991: 300 SE, 300 SEL, 380 SE, 380 SEL, 420 SEL, 500 SEL, 560 SEL, 360 SEC, 500 SEC, 580 SEC, 300 SD TURBODIESEL, 300 SDL TURBO, 350 SD TURBO, 350 SDL TURBO
Loud Knocking Engine
Old Nov 2, 2007 | 10:19 PM
AZIRRIGATION's Avatar
Vehicle is a 1987 560 SEL with 169000 miles. New timing chain, timing chain tensioner, and top three guide rails at 167000 miles (6 months ago).
While driving home from a short 5 mile trip I noticed the coolant temperature was up close to 100 degrees, so I stopped and topped off coolant reservoir with about 20 ounces of water. Now driving at 45 mph I notice the coolant temp rise up past 120 deg (red zone) in less then a mile. I drove another ½ mile to my house and let it idle, turned heater on high, opened the hood, and went to get some water. Took me 3-5 minutes to get some water and now the engine is making a LOUD KNOCKING noise.
It’s hard to pin point the exact location of the KNOCKING sound, but I’m 95% sure it’s coming from the engine on passenger side. I removed the passenger side cam/valve cover and everything looked normal, so I pulled the spark plugs and the plug closest to the firewall is wet and doesn’t look like it‘s been firing.
Does anybody know what the KNOCKING noise might be or have any suggestions on what I should do?
Old Nov 3, 2007 | 12:08 AM
elolson's Avatar
380se
Probably a broken rod. Don't start it or drive it until you have had it checked out. You could drop the oil pan and take a look. A broken rod is not always the end of an engine if it is caught right away. But combined with the overheating that is not a good combo.
Old Nov 3, 2007 | 03:44 AM
elolson,
Thanks for replying, I am also thinking a bad rod or bearing could be making the knocking sound. I guess I'll be dropping the oil pan.
Anybodyelse have suggestion's???
Justin
Old Nov 5, 2007 | 12:17 PM
Richard / E320's Avatar
2001 E320
Sounds like the motor let go; did you check to see if there is water in the oil? Is the oil milky looking? If it was overheating, might have a blown head-gasket. If the motor is overheating, I don't think I would leave it running 'unattended' for even a few minutes... what was the temperature reading when you came back out to the vehicle and you heard the knocking? Sounds like a rod to me too... please post an update when you can...
Old Nov 5, 2007 | 03:01 PM
Richard,
The temp was still about 120 deg after getting water. There is no water/coolant in oil.
Oil pressure is 2 bar when I turn engine over with coil wire unplugged.
I decided to check the hydraulic valve clearance compensating elements (05-211) since I had cam/valve covers off. While checking each compenstor I was able to push down the compensator for the exhaust valve at cylinder #4 and now it is stuck down and the rocker arm is loose. The manual say's to replace any compensator that can be pushed down faster then the others.
Could this be causing the loud KNOCKING noise?
How do I get compensator unstuck? Can I turn engine over with the rocker arm being so loose?
Is the "hydraulic valve clearance compensating element" the same or another name for the "Cam Follower", "Hydraulic Lifter", or "Hydraulic Ball Stud Assembly"?
