please help with my sec problems... any ideas?
my last main problem is a miss fire!
the whole ignition system is new...
plugs
leads
distributer rotor arm
idle controll unit.....
then
fuel filter
oil
air
cleaning of k jet fuelling system
this was all done by a mechanc friend of mine and has solved allot but there is still an obvious problem
we think its either the injectors or the k jet fuelling system
i have spent £2000 so far restoring the car and need to be carefull with money now..
the symptoms are:
lumpy idle
lumpy pulling away
clears up just below 2000 rpm on acceleration
trouble starting needs gas pedal(does this suggest leaking injectors??)
what should i do any ideas??
thanks everyone
how can i test that fuel pressure regulator valve??
thanks
One way of course is to hook up a fuel pressure gague and watch the reading while the car is running, then watch the pressure when the car is shut off and see if it continues to drop over time.
The other, non-scientific way to test it would be to basically prime the fuel lines before trying to start the car and see if anything is better or worse. To do this, turn the key from off to position 2 (run) for 3-5 seconds, repeat 20 times or so before actually trying to start the car. Since the fuel pumps run for a couple seconds in position 2 before the car is started, doing this enough should build up enough fuel pressure to tell you if it is an issue.
yes the car starts much better when it has been running and the longer u leave it, the worse it gets...
i tried your method of the 20 times priming thing, it didnt seem to make a differeance.. i dont have a fuel pressure gague.
someone suggested that the lumpy idle and bad starting would be because the injectors are broken and leaking fuel into the cylinders when the car is left, therefore fludding the engine before u even try to start the car...
does this sound like it could be true?
do u still think it could be this fuel pressure regulator? should i try to get hold of a pressure tester??
thanks so much for the advice!!!
is there any way i can check if they are the problem before taking them out??
i have been told it could also be the k-jetronic system thing that sits on top of the throttle body, i noticed someone was saying on another thread that they had to change a valve thing in it to sort a similar problem...
wondering what to do first, should i just take the injectors out and have a look??
what are the signs of them being broken?? or these plastic caps being broken,.. is it obvious?
sorry for being so confusing and difficult.
thank you so much for the advice
