S-Class (W126) 1979-1991: 300 SE, 300 SEL, 380 SE, 380 SEL, 420 SEL, 500 SEL, 560 SEL, 360 SEC, 500 SEC, 580 SEC, 300 SD TURBODIESEL, 300 SDL TURBO, 350 SD TURBO, 350 SDL TURBO
Blinking seat lights
Old Dec 23, 2007 | 10:27 AM
94E420's Avatar
2006 SL500
Question Blinking seat lights
Hello all,
Yesterday while sitting at a stop light both front heated seat lights started blinking. Both were set to high as we had only been in the car 10 min. and it was 19 outside. The car this happened on is my 1989 560SEL. So, what causes the seat lights to blink?
Thanks & Happy Holidays!!
Allan
Overland Park KS
Old Jan 26, 2008 | 09:25 PM
BBeckerCabriole's Avatar
1988 560SL, 1994 E320A, 1998 S500V
Heated Seat Lights Blinking
This Happens When the Voltage Drops Below 11V, So It Turns off Any Accessory Equippment, That is Not Necessary, You Heated Back Window Can Do This as Well, I'm Assuming You had the Heater Blasted, and Other Elect. components on, if the car is charging fine, I would not Worry About it, Its normal for them to turn off if the voltage gets too low......
