S-Class (W126) 1979-1991: 300 SE, 300 SEL, 380 SE, 380 SEL, 420 SEL, 500 SEL, 560 SEL, 360 SEC, 500 SEC, 580 SEC, 300 SD TURBODIESEL, 300 SDL TURBO, 350 SD TURBO, 350 SDL TURBO
Transmission mounts
Old Apr 1, 2008 | 05:03 PM
BarrysBenz's Avatar
1982 300sd
Transmission mounts
Does anyone know how to replace a transmission mount on a 1983 300SD???
Old Apr 8, 2008 | 11:14 AM
hineywineries's Avatar
It changes all the time
It's perty simple. Support the trans. Remove the 19mm nut at top of mount. Remove both 13mm bolts from mount and either jack up trans or remove 4 17mm bolts that hold trans cross member in place. Of course you reinstall in reverse order.
