S-Class (W126) 1979-1991: 300 SE, 300 SEL, 380 SE, 380 SEL, 420 SEL, 500 SEL, 560 SEL, 360 SEC, 500 SEC, 580 SEC, 300 SD TURBODIESEL, 300 SDL TURBO, 350 SD TURBO, 350 SDL TURBO
Dead transmission
Old Apr 5, 2008 | 09:46 AM
spyderkeeper's Avatar
1989 300 SDL
Dead transmission
I'm trying to help a friend troubleshoot a 300SDL transmission that went from perfectly fine, to not shifting past 2, to not going in gear at all. This happened all in the matter of weeks, so it makes me wonder if the transmission is actually done or it's something else. Is there anything I can look for by taking off the center console into the shifter? Would this be helpful? I checked the vacuum line running to the transmission and it held vacuum fine.
Old Apr 6, 2008 | 10:28 AM
BENZITCH's Avatar
1991 560SEC Teal 1989 420SEL Ice Blue 1984 500SEC White
Did you check the shifter bushings on the exterior of the trans? They can be checked easily by looking at them.
Bruce
