S-Class (W126) 1979-1991: 300 SE, 300 SEL, 380 SE, 380 SEL, 420 SEL, 500 SEL, 560 SEL, 360 SEC, 500 SEC, 580 SEC, 300 SD TURBODIESEL, 300 SDL TURBO, 350 SD TURBO, 350 SDL TURBO
Gears not changing?
Old Jul 6, 2008 | 06:14 AM
lessteaks's Avatar
Gears not changing?
Hi all,
My car (MERC '84 500SEC) has been off the road for a few months. Went for a drive yesterday and I'm not sure the auto box is changing gear i.e. the revs just keep rising as you accelerate e.g. was at 4000+ when driving at 100 kmph. Does this sound right to you? Any ideas on cause?
Thanks,
Les
Old Jul 6, 2008 | 12:46 PM
560er's Avatar
change gear oil and filter for a start
Old Jul 6, 2008 | 02:01 PM
lessteaks's Avatar
Will give that a go - thanks!!!
Old Jul 7, 2008 | 04:46 PM
tinypanzer's Avatar
300 Sonderklasse E
Look for vacuum leaks! I'll bet you have a cracked vacuum hose, especially if it worked "just fine" when you last drove the car.
Old Jul 10, 2008 | 04:21 PM
tinypanzer's Avatar
300 Sonderklasse E
Any luck?
If you want I can go through the MB diagnosis info and see what it says.... Takes a while to do that, so let me know if you still need help
Old Nov 7, 2009 | 02:17 PM
benm's Avatar
s320cdi 420se e220cdi
I have a similar problem. Car won't change into 3rd or 4th gear (420se w126). Could you outline the diagnostics process.
Ben.
