S-Class (W126) 1979-1991: 300 SE, 300 SEL, 380 SE, 380 SEL, 420 SEL, 500 SEL, 560 SEL, 360 SEC, 500 SEC, 580 SEC, 300 SD TURBODIESEL, 300 SDL TURBO, 350 SD TURBO, 350 SDL TURBO
Air or Heat turns on and off intermittently
Old Aug 18, 2008 | 05:20 PM
taktiks's Avatar
1988 Mercedes-Benz 300 SEL
I have an '88 300 SEL and when it's hot outside and the air is on it will just turn off and then start up again. Same with heat. Sound like an internal thermostat?
Old Aug 29, 2008 | 02:28 PM
jnawrocki's Avatar
1988 420SEL
Air Heat
It could be the temperature sensor but it could also be a faulty ignition switch. Try wiggling the switch slightly when fan is off and see if comes right back on.
Old Aug 29, 2008 | 04:13 PM
nsmith17044's Avatar
1990 560SEL
Climate Control
Do you mean the fan / blower is turning on and off? When the air cond. is on, do you know if the air cond. compressor is still engaged? If not, this points to power supply or the controller. If the compressor is still engaged I would start looking at the blower motor control.
I have seem a cracked fuse (the big flat type) cause intermittent behavior like you describe but everything will be off including the air cond. clutch. I would verify all of the fuses and the power connections on the controller and the fan motor.
If you have the 126 body service manual CDs there is a trouble-shooting guide that you can walk through that might help pin down the problem.
Good luck.
