S-Class (W126) 1979-1991: 300 SE, 300 SEL, 380 SE, 380 SEL, 420 SEL, 500 SEL, 560 SEL, 360 SEC, 500 SEC, 580 SEC, 300 SD TURBODIESEL, 300 SDL TURBO, 350 SD TURBO, 350 SDL TURBO
Power Locks, On-Off-On-Off-On-----
Old Sep 12, 2008 | 10:33 PM
royzell's Avatar
1984 300SD
Question Power Locks, On-Off-On-Off-On-----
Hi All,
I have an '84 300SD. The locks worked fine when we got the car about a year ago, but last winter the locks malfunctioned, continually switching on and off with no stop (door buttons up and down, etc.)
I stopped the problem by disconnecting the electrical pump in the trunk, but no power locks.
I tried fixing it recently by removing the electrical cover from the same unit, and removing all corrosion with WD-40. I installed the pump and it worked fine for a day or 2, then the same old problem recurred.
The pump was running continually, warm to the touch. I disconnected it, and tried a spare from my parts car. Same thing.
Any ideas ?
Old Sep 12, 2008 | 11:47 PM
Untertürkheim's Avatar
Originally Posted by royzell
Hi All,
Any ideas ?
Sounds like a vaccuum leak causing th pump to run.
