S-Class (W126) 1979-1991: 300 SE, 300 SEL, 380 SE, 380 SEL, 420 SEL, 500 SEL, 560 SEL, 360 SEC, 500 SEC, 580 SEC, 300 SD TURBODIESEL, 300 SDL TURBO, 350 SD TURBO, 350 SDL TURBO
LSD
Old Dec 16, 2008 | 02:18 PM
eloc206's Avatar
1985 380SE and 2007 GL 450
LSD
looking to add LSD on my 380SE what models carry this option... thanks
Old Dec 16, 2008 | 02:56 PM
Untertürkheim's Avatar
560 models have it, but the 500 may also.
The problem is that the gearing is wrong on a 560 diff. Also, a 380 would not benefit much if at all from an LSD.
Old Dec 16, 2008 | 03:10 PM
eloc206's Avatar
mmm so it wouldn't be even worth my time and money to install...
Old Dec 16, 2008 | 03:23 PM
Probably not, unless you are running a tuned euro engine. The 380 has a 2.24 diff ratio, the same as the 500, to accomodate for the low redline. The 560 has a 2.46 differential.
I have actually considered switching to a 2.24 on my 560 if I can find one with LSD.
Old Dec 16, 2008 | 03:45 PM
elolson's Avatar
380se
I also run a 380se. They just don't have enough power to justify a LSD as I can't even get the tires to slip now unless I am on dirt .
Old Dec 16, 2008 | 04:23 PM
eloc206's Avatar
nice... i guess i'll be keeping an eye out for the 500 differential then... pricing would be the deciding factor... thank you for the info
yeah i know what you mean... thought of installing an lsd would at least give me more traction in the dirt or rain
