S-Class (W126) 1979-1991: 300 SE, 300 SEL, 380 SE, 380 SEL, 420 SEL, 500 SEL, 560 SEL, 360 SEC, 500 SEC, 580 SEC, 300 SD TURBODIESEL, 300 SDL TURBO, 350 SD TURBO, 350 SDL TURBO
Performance a little sluggish
Old Jan 5, 2009 | 01:38 PM
Berde's Avatar
1987 300 SDL
I have noticed that my 300 SDL is not as peppie when going uphills or above 80 MPH. I have done diesel fuel filters change, fuel pump seals and o-rings change, and trany service among other things. The car has no leaks and is not burning any oil. I have driven other 300 SDLs that have a little more punch than mine with double the mileage (mine is only 140,000). I was thinking about checking the electronic turbo control if they have any, waste gate, or hose issues that might explain this hickup. Any ideas where to start?
Old Feb 13, 2009 | 01:52 AM
mazdawg89's Avatar
300 SDL
please let me know if you solve your problem, I have the same problem!
I have a 86 300SDL. I will be sure to post if i find a solution!
Old Feb 13, 2009 | 06:58 PM
Untertürkheim's Avatar
Check the vacuum system for leaks, and timing chain stretch, and injectin pump timing.
