S-Class (W126) 1979-1991: 300 SE, 300 SEL, 380 SE, 380 SEL, 420 SEL, 500 SEL, 560 SEL, 360 SEC, 500 SEC, 580 SEC, 300 SD TURBODIESEL, 300 SDL TURBO, 350 SD TURBO, 350 SDL TURBO
wobble(pcd) bolts
Old Mar 25, 2009 | 12:05 AM
morris374's Avatar
1991 420SEL & 300E, 2003 BMW X5, 2001 740iL all on DUBS
wobble(pcd) bolts
Ive been wanting to use Pcd variation lug bolts to put 5X108 wheels on a 5X112 application will it work or is the difference to big? Because i was originally going to buy wheel adapters but im afraid the the offset will be to big if the that is done
Any info helps
Old Mar 28, 2009 | 02:05 AM
morris374's Avatar
found out that wobble bolts are only good for <2.5mm so 5x112 to 5x114.3, 5x112 to 5x110
Old Apr 7, 2009 | 01:27 AM
morris374's Avatar
has anyne had a bad experience with Wobble bolts? cause it looks im buyin them this weekend
Old May 1, 2009 | 08:35 PM
BADwayz's Avatar
German
Check with the VW guys over at Vortex, they would know way more about them than over here. But I wouldnt chance using them for a 4mm difference. Depending on the backspacing, I would go with adaptors and stretched tires instead.
