S-Class (W126) 1979-1991: 300 SE, 300 SEL, 380 SE, 380 SEL, 420 SEL, 500 SEL, 560 SEL, 360 SEC, 500 SEC, 580 SEC, 300 SD TURBODIESEL, 300 SDL TURBO, 350 SD TURBO, 350 SDL TURBO
gas-a-just shocks
Old Mar 25, 2009 | 12:20 AM
morris374's Avatar
1991 420SEL & 300E, 2003 BMW X5, 2001 740iL all on DUBS
gas-a-just shocks
ive had a set of gas-a-just shocks on the rear of my car for like a year now but lately they have been sagging can they be adjusted or refilled or are they only self adjusting?
Old Apr 7, 2009 | 01:32 AM
morris374's Avatar
is there a leveling system in 420SEL like in the 560sec? is that y the rear might be sagging? I just want to figure it out before i put my new rims on and get wheel rub on the tires!!
Old Apr 30, 2009 | 04:06 PM
Berde's Avatar
1987 300 SDL
If you are talking after market, then gas shocks that are bad cannot be refill. But if shocks are OK, then check springs because they are designed to level and keep the car at a normal ride height. Shocks keep the car from bouncing like an urethane ball when springs due their trick.
Old May 1, 2009 | 03:04 AM
morris374's Avatar
ohhh... that makes sence thanks for the info
