window problems/Odometer not moving
Get a PDF download of the car service manual, it will help. You should be able to find one online for about $10.
The sunroof has a manually operated device in the trunk to see if it opens or is seized. If it opens, then possibly the motor or fuse. The fuses in these cars may look good, but are bad, so you have to change them out to be sure.
When changing the fuses out best to use the copper ones vs. the aluminum fuses.
But my mechanic said its a good buy! Says it needs R12 freon ... does anyone know where i can buy some for Cheap? I don't feel like spending another 300-$400 to convert to R134 .... please let me know guys! Thx
I know I buy it when I can find it.
I also have the same issue with the odometer. It started after I filled the car with fuel and tried to reset the trip odometer. After that the main and the trip odometer stopped working. I'm guessing the problem is in that knob assembly, but I haven't looked at it as yet.
