1989 300SE Rear Door Lock Actuator
1985 380SE US SPEC
dang, wish i would have checked on here sooner. my rear door actuator broke about the same time as yours, but didnt know it because my door had seized from a broken check strap. When i finally got it open over the weekend i replaced the strap and then found when that broke it also took off the top of the actuator! After a few hours trying to McGyver the thing back together i gave up (which next time i know what to do) and found one on ebay from a parted out SDL for $7. I was told by the dealer that a new one (superceded part number from original) would be $72, plus you will probably need a little adapter to fit the vacuum hose which is another $7. I'll try the used one first..
