S-Class (W126) 1979-1991: 300 SE, 300 SEL, 380 SE, 380 SEL, 420 SEL, 500 SEL, 560 SEL, 360 SEC, 500 SEC, 580 SEC, 300 SD TURBODIESEL, 300 SDL TURBO, 350 SD TURBO, 350 SDL TURBO
560SEC hard starting
Old Sep 27, 2009 | 11:22 AM
raybenz's Avatar
560 SEC
Angry 560SEC hard starting
My car has been parked for a long time. I had it emission test and burned my ignition module. I had a mechanic checked and it was the module. I got it replaced.
The car would not start, except when I put some gas in the intake. Once the fuel runs out int he manifold it shut down. So i checked the fuel pump. I replaced the fuel pump and filter.
This time I still put gas in the intake manifold to start. The car will keep running till I turn the key off. It would not start again, after I turn it off.
Some how the fuel will not go to the manifold or the cylinder.
What steps should I do to check the fuel is going to the cylinder?
