S-Class (W126) 1979-1991: 300 SE, 300 SEL, 380 SE, 380 SEL, 420 SEL, 500 SEL, 560 SEL, 360 SEC, 500 SEC, 580 SEC, 300 SD TURBODIESEL, 300 SDL TURBO, 350 SD TURBO, 350 SDL TURBO
Center Console on a W126
Old Oct 20, 2009 | 01:26 AM
hime's Avatar
1981 300SD
How do you remove the center console or side panel to get at the carpeting over the transmission tunnel?
Old Oct 24, 2009 | 12:19 AM
schurmann's Avatar
1989 300 SE
Do you know about the screws under the ashtray?
The following is for my '89 300SE, yours might be different.
If you remove the ashtray drawer, push the release to slide out the ashtray and lay to one side.
Remove the two screws there under the drawer.
Move away the ashtray assembly.
Take out leather coin cup.
take up wood panel w/window switches.
Thats as far as I know- we stopped there to replace a window switch, hope this is a good start.
Old Oct 31, 2009 | 03:01 PM
Halient's Avatar
SEL 420 Lexus SC300
mine had 2 small screws on the bottom that just had to be removed
