S-Class (W126) 1979-1991: 300 SE, 300 SEL, 380 SE, 380 SEL, 420 SEL, 500 SEL, 560 SEL, 360 SEC, 500 SEC, 580 SEC, 300 SD TURBODIESEL, 300 SDL TURBO, 350 SD TURBO, 350 SDL TURBO
no reverse
Old Dec 14, 2009 | 10:32 PM
freddie530's Avatar
1984 300sd
no reverse
reverse problem '84 300sd,need solutions help!
freddie530
Old Dec 16, 2009 | 10:37 AM
beeman's Avatar
82 mb 300sd, 85 mb 300sd, 96 Niva, 80 300sd parts car
What is it doing?
Old Dec 16, 2009 | 12:59 PM
freddie530's Avatar
1984 300sd
freddie530
Thanks for reply, This tranny is doing several things.
1. Does not engage reverse, linkages are connected.
2. slips from first to second never seems to get into third or fourth.
3. changed fluid and filter
4. adjusted bowden cable
5. checked vacuum lines to modulator/ and engine for faulty connection.
6. have not preformed a vacuum pressure test.
In a nutshell thats it, any other suggestions?
Old Dec 17, 2009 | 04:28 PM
JayKinFL's Avatar
2010 GL550, 2008 CLK55
I had a somewhat similiar problem with my 1991 420SEL. It turned out that I had a faulty kickdown switch (which is located on the floorboard, directly behind the top of the accelerator pedal). With the kickdown switch button stuck "in", as was the case with mine, the car was not able to leave 2nd gear. I do not know if reverse was affected, because I was able to discover and correct the problem before I had to put the car in reverse. Replacing the part was simple (no tools necessary) as the kickdown switch is held in place by two pinch tabs. Diagnosing the switch was simple - press on it (firmly), and it should "click" with pressure applied. When released, it should pop back up with a "click". Mine was stuck in the down position, and when I wiggled it, it popped back up with such force that the button came off in my hand.
Old Dec 18, 2009 | 12:29 AM
freddie530's Avatar
1984 300sd
It was checked along with the other stuff in the manner that you described, it was not stuck in the down position; any other suggestions.
Old Dec 20, 2009 | 09:53 PM
dan_the_man_au's Avatar
1990 w126 300se
Time to get the transmission rebuilt
Old Dec 22, 2009 | 02:10 AM
troublesome's Avatar
1988 & 89 300SE (W126)
I have also been trying to find out some information regarding this issue and came across the website below. I don't know if it is a solution for your exact problem but they do have some suggestions on what to look for and do.
http://www.europeantransmissions.com...merc/97-20.pdf
http://www.europeantransmissions.com...erctechlib.htm
Old Dec 30, 2009 | 11:16 AM
freddie530's Avatar
1984 300sd
no reverse
Thanks for the info, I'll check it out and let you know the results.
freddie530
