S-Class (W126) 1979-1991: 300 SE, 300 SEL, 380 SE, 380 SEL, 420 SEL, 500 SEL, 560 SEL, 360 SEC, 500 SEC, 580 SEC, 300 SD TURBODIESEL, 300 SDL TURBO, 350 SD TURBO, 350 SDL TURBO
300 SDL late shifting issue
Old Jan 15, 2010 | 06:23 PM
The Toecutter's Avatar
Mercedes Benz 300 SDL
I own a Mercedes 300 SDL. Recently, it began to shift at a much higher RPM than normal. Normally, it shifts up at 2500 rpm or so from 1st to 2nd gear; now, it tends to slip shifting from 1st gear to 2nd gear. When 2nd gear is engaged, there is a noticable but brief surge of acceleration, then more slipping if the accelerator is pressed too hard.
A transmission shop took the transmission out of the car(under warranty), ran a few tests on it, and could not find any errors(they may be lying about that). Any indication as to what could be the cause of the problem?
If the transmission is not an issue, perhaps this is vacuum related?
