Putting on Alternator belt
1985 mercedes benz 380se
![Exclamation](https://mbworld.org/forums/images/icons/icon4.gif)
I just bought a new belt yesterday and I a stumped on how to put it on. I have been tinkering with it and cant figure it out.
I see that I have to remove two belts in order to put the new one on, however I cant find the bolt or bolts to release the tension to slide them on and off. I called the auto repair shop and they want over 100 dollars to put on a belt. I am trying to figure this out to save money.
Has anyone out there done this before......What am I doing wrong????
SL600 r230, SL600 r129,, SL500 r230, ML320, C280 Sport, 190e 2.3 16V (2)
I know of at least two tensioning schemes.
In all cases all the nuts and bolts must be loosened.
One scheme has a gear set up on the bolt itself.
The other has an adjusted that comes out the side of the bracket.
A flashlight helps, and it probably will become aparant to you if you look at it from underneath.
1982 300SD TURBO DIESEL
