560 SEL fuel pump relay bridged
1986 560SEL (W126)
Hello
I had trouble with my 1986 560SEL. It would start but then die right away after I release the key from the start position.
I bridged the fuel pump relay which is doing the job. The engine stays on all the time.
Now i bought a new "used" fuel pump relay but have the same trouble with it: Engine starts...and dies after a few seconds?
Do you think the second fuel pump relay is also bad? What could it be?
I should add that i only did the tests on battery power only, because my alternator needs to be changed as well.
Your help is appreciated.
1986 560SEL (W126)
Which relay is right?
Hi
My car had a 0035452405 relay in it. When I look it up online at different MB Part stores it tells me that 0035452505 should be right?
Anyone has an idea which one to use?
