S-Class (W126) 1979-1991: 300 SE, 300 SEL, 380 SE, 380 SEL, 420 SEL, 500 SEL, 560 SEL, 360 SEC, 500 SEC, 580 SEC, 300 SD TURBODIESEL, 300 SDL TURBO, 350 SD TURBO, 350 SDL TURBO
Which warning light it this?
Old Apr 14, 2010 | 11:12 AM
EFiftyFive's Avatar
2003 E55 AMG
Bought an 86 420 SEL with no owners manual. Warning light between the emergency brake light and the oil level light came on this morning (it's a circle with three dots on each side). Which warning is this?
Old Apr 14, 2010 | 09:08 PM
waybomb's Avatar
SL600 r230, SL600 r129, SL500 r230, ML320, C280 Sport, R170 450SL, 190e 2.3 16V (2)
In a few hundred miles or less, your rotors will be touching your disc brake backing plates - it is the brake pad wear warning.
Replace the sensors when you replace the pads, now that they've been touching the rotors.
Old Apr 15, 2010 | 11:51 AM
EFiftyFive's Avatar
2003 E55 AMG
Thanks for the response!
