S-Class (W126) 1979-1991: 300 SE, 300 SEL, 380 SE, 380 SEL, 420 SEL, 500 SEL, 560 SEL, 360 SEC, 500 SEC, 580 SEC, 300 SD TURBODIESEL, 300 SDL TURBO, 350 SD TURBO, 350 SDL TURBO
w126 420se high idle speed fault
Old 06-08-2010, 07:10 AM
maverickmarine's Avatar
mercedes 560sel w126
hello can any one help, we have a 420se in stock that has a high idle speed problem the idle relay and the idle valve seem to be working ok we swapped them over with my 560sel and they seemed to work fine.there appears to be no vacume leaks it just idles at about 1800 rpm.any ideas?all responses welcome thanks
Old 06-08-2010, 08:01 PM
waybomb's Avatar
SL600 r230, SL600 r129,, SL500 r230, ML320, C280 Sport, 190e 2.3 16V (2)
Did you check the OVP? What happens when you pull the OVP out while the engine is running? Then put it back in.
Same with ISC - unplug it, what happens, plug it back in.
Same with ICV - disconnect wire connector, what happens, plug it back in.
Then spray copious amounts of gumout carb cleaner all over the air distribution hoses, and under the top half of the air intake, where the air distribution hoses cross underneath it. Does the idle change at all?
Old 06-12-2010, 02:48 PM
inthemedia's Avatar
I traced my high idle problem to a faulty Throttle Position Switch (TPS). The TPS senses the position of the air butterfly valve. Unfortunately it's a bear to get to. Have to remove fuel distributor and air guide housing and all the stuffs that's in the way. In fact, I'm working on it right now. Because the air guide housing rubber has hardened over the last 20+ years, getting it off the metal butterfly housing throat is a real bear. In fact, that's where I'm stuck at the moment. I've loosened the hose clamp securing the air guide to the butterfly valve body and removed the 4 bolts holdling the assembly to the rubber mounting bushings but just can't seem to pull the assembly off. Anyone got a trick to getting it off?
Thanks,
T.C.
Old 06-23-2010, 12:05 AM
GRIMSTONE's Avatar
380 SL/ 240D stick/ 420 SEL
Smile
Thanks,
T.C.
Buy a hose removal tool from "Snap On" and slide it between the metal and the rubber---this tool will save you from breaking radiator necks in the future! GRIMSTONE.
Quick Reply: w126 420se high idle speed fault
