560 sel smokes after going down hill.
91 Mercedes 560 SEL
Hi fellow human being, I have a 91 560 that runs really well except after going down hill, after going down hill and I hit the accelerator it stumbles a little and a smoke plume look like a A-bomb just dropped. I had a BMW 2002 that would smoke WHILE I was going down hill. Caused by a bad valve seal design. I don't understand the not smoking while I'm going down hill only when I press the accelerator. Why doesn't it smoke while going down hill if it is valve seals or guides? Thanks
One of our 560sel's (either the '85 or '86 I don't remember) smokes also. The shop said it was the... valve seal or the head gasket? Either way, it was about $5000 to do the repair (which we haven't done because spending that much money on a W126 that never gets driven, just isn't worth it unfortunately).
91 Mercedes 560 SEL
I just drove home and I decided to put the car in neutral going down the hill. So the car was basically idling....press the accelerator cloud of smoke. There should have been normal vacuum. I also was driving at 45 mph and let off the accelerator should be a high vacuum situation hit the accelerator clean. It seems to me to have something to do with being on a incline nose down. Windage from the crank throwing oil in the front cylinders?
