S-Class (W126) 1979-1991: 300 SE, 300 SEL, 380 SE, 380 SEL, 420 SEL, 500 SEL, 560 SEL, 360 SEC, 500 SEC, 580 SEC, 300 SD TURBODIESEL, 300 SDL TURBO, 350 SD TURBO, 350 SDL TURBO
300 SD overheating
Old Jul 16, 2010 | 10:41 PM
Barefooter6's Avatar
500 sl
300 SD overheating
I have a 1983 300sd. I have replaced the radiator, thermostat, waterpump and bled the air out of the system. The car still wants to run at a temp just below overheating. Any answers?
Old Jul 17, 2010 | 02:49 PM
waybomb's Avatar
SL600 r230, SL600 r129, SL500 r230, ML320, C280 Sport, R170 450SL, 190e 2.3 16V (2)
Did you verify the gauge is accurate?
Does the electric fan work? When the radiator gets hot, does the fan clutch engage?
Do you loose any coolant? If so, may have a bad head gasket.
Old Jul 17, 2010 | 06:27 PM
500 sl
Thanks, The guage is accurate, the elec. fan works, clutch fan is new and I'm not losing any water.
Old Jul 17, 2010 | 07:23 PM
morris374's Avatar
1991 420SEL & 300E, 2003 BMW X5, 2001 740iL all on DUBS
try a higher concentrate of coolant like 70% coolant 30 %water rather than 50-50
Old Jul 18, 2010 | 03:13 PM
oldsinner111's Avatar
s320
As these fine diesels age,it is important to flush and clean block good.I use one gal vinegar added to water with thermostat out.Run car really good a hour or more driving.Then drain,when block is cold run water thru engine backwards.You will see chunks of rust.Run her in summer with plain water till all rust is gone,then fill her with antifreeze and distilled water.
Old Jul 18, 2010 | 08:35 PM
500 sl
Thanks, I will try that this week.
Old Jul 21, 2010 | 02:00 PM
waybomb's Avatar
50/50. Everything I've read on the websites of antifreeze manufacturers says 50/50.
If you can show me some proof that 70/30 is better, I'll accept and change my opinion. But when a marketer of a product says less is better, I gotta believe them.
