S-Class (W126) 1979-1991: 300 SE, 300 SEL, 380 SE, 380 SEL, 420 SEL, 500 SEL, 560 SEL, 360 SEC, 500 SEC, 580 SEC, 300 SD TURBODIESEL, 300 SDL TURBO, 350 SD TURBO, 350 SDL TURBO
Advice on buying a 1981 MERCEDES 380SEL
Old May 22, 2003 | 11:32 AM
kompress's Avatar
How did the gas engines do with higher mileage? What advice can you give a newbie? What should I be looking for? For example
- when does the timing chain need to be changed and how much does that run?
- what kind of mileage does this car get?
- what are the problem spots on this car?
- how much should I be looking to spend?
I appreciate any input.
Old Jun 3, 2003 | 08:56 PM
dtkw's Avatar
1986 560SEL, 97 BMW 740iL
The 380SEL came with a single timing chain. Most owners probably had upgraded it to the double already. That's one thing you need to look for. As for your other questions, I think it has reasonable power and mileage for its size and weight. I only got around 15 or 17 on my 560SEL. The only time it did well was on the highway to Chicago and I got 360 miles in that tank before filling up. The 380 should do better, I think.
