S-Class (W126) 1979-1991: 300 SE, 300 SEL, 380 SE, 380 SEL, 420 SEL, 500 SEL, 560 SEL, 360 SEC, 500 SEC, 580 SEC, 300 SD TURBODIESEL, 300 SDL TURBO, 350 SD TURBO, 350 SDL TURBO
FS: Injector Pump for 1976-1985 Turbo Diesel
Old Nov 11, 2011 | 02:24 PM
Tim Wheeler's Avatar
300SD 1982
Ends Sunday night. In case you missed this, I wanted to give this forum a heads up: http://www.ebay.com
This is the injector pump off my totaled 1982 300SD Turbo-Diesel with 141,000 original miles. I believe this pump is valid for 1977-1985 Mercedes Benz 5 cylinder turbo-diesel engines. These years had the same engine, but please check to verify it will work on your engine. Other years may see some variations on the external components. It is up to you to verify compatibility with your diesel engine.
This particular car was stored in a garage for 15 years during the 90's and early 2000's. When I bought it I installed new fuel lines and diesel purged the system.
Cheers!
I'm starting the bid really low to gains some interest. Shipping is only $28.. I'll probably lose a few bucks on that..
It ran like a top. Lots of power. You'll be hard pressed to find a injection pump with this few miles on it.
Thanks!
