S-Class (W126) 1979-1991: 300 SE, 300 SEL, 380 SE, 380 SEL, 420 SEL, 500 SEL, 560 SEL, 360 SEC, 500 SEC, 580 SEC, 300 SD TURBODIESEL, 300 SDL TURBO, 350 SD TURBO, 350 SDL TURBO
Heat and A/C blowing at same time
Old May 13, 2012 | 12:31 PM
jamesta's Avatar
1987 560 SEL
I'm having some issues with my climate control:
The heat and A/C blow at the same time
Makes a loud "clank" noise when 'switching' from heat to A/C (even though both blow at the same time)
Will not stay off, even when "0" is selected it comes off/on intermittently
Any suggestions are appreciated, I've tried switching climate control units and that doesn't make a difference so it's not the unit itself.
Old Jul 9, 2012 | 09:06 PM
PelicanParts.com's Avatar
SPONSOR
Answer
My first guess would be a damaged mono valve diaphragm.
Mono Valve Repair Kit - Heater Solenoid Valve
MB# 0008350644
Further suggestions and diagnosis can be found in this link.
Mono valve links thread
http://www.peachparts.com/shopforum/...ml#post2514617
roy@pelicanparts.com
