S-Class (W126) 1979-1991: 300 SE, 300 SEL, 380 SE, 380 SEL, 420 SEL, 500 SEL, 560 SEL, 360 SEC, 500 SEC, 580 SEC, 300 SD TURBODIESEL, 300 SDL TURBO, 350 SD TURBO, 350 SDL TURBO
300td question
Old Jul 14, 2003 | 02:40 PM
oldbrown's Avatar
1985 300td
300td question
This old girl may be too old for some of you sleek, fast types, but if you have any ideas I'd appreciate the feedback.
I am the 2nd owner of a 1985 sedan. The vehicle has been serviced regularly and I have had no problems with her until this past weekend on the interstate.
After running about 150 miles at 75mph I noticed a roaring noise begin in the rear. I pulled off at the 1st exit and rolled down the rear windows to hear clank, clank, clank....and as I slowed the clanking decreased with each rotation.
Pulling away from my stop I noticed that the noise was completely gone. I pulled into a bay and lifted the car to look for an obvious sign of damage, nothing.
Put her back on the road and in about 100 miles or so the same roar and then clanking as I pulled off. I found as I came to a complete stop and started again the noise was gone and the vehicle ran fine for another 100 or so miles. Each time the roar would start I would pull over to a complete stop and once moving the noise would be gone.
Anyone have any ideas on this situation?
Old Jul 14, 2003 | 03:18 PM
dtkw's Avatar
1986 560SEL, 97 BMW 740iL
Check your turbo system to see if everything is tight, not loosed. Of course, do that when the car is cool.
Old Jul 14, 2003 | 03:33 PM
oldbrown's Avatar
1985 300td
Appreciate the feedback.
How does the turbocharger figure in with a rear axle roaring/clanking?
Old Jul 14, 2003 | 04:14 PM
dtkw's Avatar
Oh, sorry, missed that part. then check your exhaust system, high speed = more pressure. If you have a small leak on your pipes and muffler, things might get louder when you are going faster. That's my guess.
Old Jul 14, 2003 | 04:43 PM
oldbrown's Avatar
1985 300td
Thanks again.
I'll check the exhaust and hopefully that's the problem since it would be less expensive than something in the rear axle.
I figure if it were an axle/differential problem, that the problem would not go away by stopping and starting again.
Old Jul 14, 2003 | 04:45 PM
dtkw's Avatar
Good luck and hope you find the problem soon and enjoy the ride again.
