S-Class (W126) 1979-1991: 300 SE, 300 SEL, 380 SE, 380 SEL, 420 SEL, 500 SEL, 560 SEL, 360 SEC, 500 SEC, 580 SEC, 300 SD TURBODIESEL, 300 SDL TURBO, 350 SD TURBO, 350 SDL TURBO
126 body evap temp sensor?
Old 08-01-2012, 07:12 PM
jobaa's Avatar
'86 300sd, '00 ml320
does anyone know where the evap sensor is on the '86 300SDL? how hard is it to change?
Old 10-17-2012, 12:03 AM
blowfish's Avatar
81 300sd, 83 300dT, F350, 250 diesel & 16 ft car trailer
i think the evap valve on A/C is inside the foot well, if u drop the padding under your legs u should be able to see.
almost need to run water into the a/c coil, as my inside heater core has some mild leak.
did that on my 190 w 201, as core is a leakin like a sieve.
Quick Reply: 126 body evap temp sensor?
