S-Class (W126) 1979-1991: 300 SE, 300 SEL, 380 SE, 380 SEL, 420 SEL, 500 SEL, 560 SEL, 360 SEC, 500 SEC, 580 SEC, 300 SD TURBODIESEL, 300 SDL TURBO, 350 SD TURBO, 350 SDL TURBO
HELP!!! Trottle linkages function/adjustment
Old Oct 23, 2012 | 11:30 AM
mygr8star's Avatar
95 e320 cabrio, 89 420 sel, 91 300e
Fellow MB enthusiasts, Could any of you help me understand the functioning of the trottle linkages of a '89 420 SEL. I had a rebuild (722....) tranny installed,
now I need to make adjustments so it shifts and kicks down when needed. However I cannot find any guiding in setting up the linkages properly.
I have the tranny pan removed so I can see what the plunger does when the bowden cable moves. I suspect that this movement is not enough, so adjustment in the linkages is needed.
Hope someone responds as I'm dead in the water.
Old Oct 31, 2012 | 02:58 AM
PelicanParts.com's Avatar
SPONSOR
Answer
These two documents have the data you need.
You must use Internet Explorer to view them..
http://www.startekinfo.com/StarTek/o...103/30-300.pdf
http://www.startekinfo.com/StarTek/o...103/30-325.pdf
roy@pelicanparts.com
