S-Class (W126) 1979-1991: 300 SE, 300 SEL, 380 SE, 380 SEL, 420 SEL, 500 SEL, 560 SEL, 360 SEC, 500 SEC, 580 SEC, 300 SD TURBODIESEL, 300 SDL TURBO, 350 SD TURBO, 350 SDL TURBO
help on headlight part no euro 420 sel
Old Feb 1, 2013 | 02:56 AM
dennis.kde's Avatar
86 420 sel, 91 mercedes 190E
I need the mercedes part no for the glass euro headlight that fit a w126 se/sel 1986 with vacume adjusters. I have a set of after market lights and need the part number so M/b dealer can order me the 5 pin plugs for the wires. lights work with wires just pluged on but I would like the plug to put them in
Old Feb 22, 2013 | 05:42 PM
scoto's Avatar
2005 E55, 2007 ML63, 2008 SLK, 2015 GLK350, BMW Z3, Dodge Power Wagon, Electric Smart car
qty (2) - 006 545 80 28 - six-pin electrical connector, socket
qty (2) - 009 545 30 28 - six-pin electrical connector, cover
qty (2) - 003 545 26 26 - pin, connector (female pin sockets for city lights) this is optional
Old Feb 22, 2013 | 11:08 PM
dennis.kde's Avatar
plugs
on these plugs is one left blank when you use city ligths. My lights have 5 pins
Old Feb 23, 2013 | 10:15 AM
scoto's Avatar
re: plugs
The # 1 pin is left blank. See attached PDF file with wiring info
File Type: pdf
Old Feb 23, 2013 | 11:50 AM
dennis.kde's Avatar
thank you
Thank you very much. this helps get it done properly.
Would you have the same info for a 1991 190E
Dennis
Old Feb 23, 2013 | 01:17 PM
scoto's Avatar
for 190E it should be the same. check out this thread as it has every thing you will need.
http://www.benzworld.org/forums/w201...eadlights.html
Old Feb 23, 2013 | 05:24 PM
dennis.kde's Avatar
thank you agian
thanks alot I will be getting this done soon
