S-Class (W126) 1979-1991: 300 SE, 300 SEL, 380 SE, 380 SEL, 420 SEL, 500 SEL, 560 SEL, 360 SEC, 500 SEC, 580 SEC, 300 SD TURBODIESEL, 300 SDL TURBO, 350 SD TURBO, 350 SDL TURBO
W126 New Water Pumps Available Now! By Pelican Parts
Old Jun 14, 2013 | 12:42 PM
PelicanParts.com's Avatar
SPONSOR
Is your car starting to run a little hot? Is it overheating while sitting at idle? It's possible you may need to replace your water pump. An easy way to check your water pump is to look underneath the car and check for water seepage out of the pump. This means that water is leaking past the bearing and seals, indicating the pump is on its way out.
We offer NEW not rebuilt replacement pumps ready to ship today! You may choose from several brands by clicking below:
W126 Water Pump Options
If replacing the pump yourself, check out our tech article which explains the process:
W126 Water Pump Replacement Step-By-Step
As always, let us know if you have questions any time!
